1) This was a not a made up story. Do you really think this is beyond the realm of possibility?Originally posted by growler:
peter d, first off, you said that you had been informed by a co-worker that an inspector carried a light meter. Rule NO.1 " Don't believe everything you hear". Someone has already changed that to light saber. If he does have a light meter there may be a reason for it. Someone may have fallen down a dark stairway and broke his neck. Stairway, kitchens & bathrooms require light fixtures and not switched receptacles. If an incident happened it would not be uncommon for the local authorities to take notice and start acting like they are doing their jobs. If you have a problem call the head electrical inspector and get to the bottom of it. I herd a story about a chicken that thought the sky was falling. It turned out to be untrue.
Maybe, maybe not. It helps to remember that the NEC isn't the only code we must adhere to. Perhaps he is enforcing energy code (though as I stated earlier, a light meter is a poor way to do so.) Perhaps he is enforcing a local code addendum, or a state code addendum. I don't reside in your area, so I don't know what codes are enforced, but there are often more than just the NEC to consider.Originally posted by peter d:
2) The code only requires a lighting outlet, not a luminaire. He has no right to enforce light levels in a dwelling unit.
The guy likes Beaver? Who doesn't?Originally posted by electricmanscott:
Seriously though if it's the guy I think it is they might have said he is a "Light eater". Very skinny fella.![]()
This is just plain weird. So it appears that residential electrical installations must either meet the NEC or the IRC. I don't know how one would know which code to use, when we are give the option to comply with one or the other.(A) Covered. This Code covers the installation of electric conductors, electric equipment, signaling and communications conductors and equipment, and fiber optic cables and raceways for the following:
b. installations in detached one- and two-family dwellings and multiple single-family dwellings (townhouses) not more than three stories in height with a separate means of egress and their accessory structures shall be in accordance with the requirements of this code [the NEC] or with the requirements of the 2003 International Residential Code portion of the 1999 State Building Code;
(B) Not Covered. This code does not cover the following:
(6) Installations in one- and two-family dwellings and multiple single-family dwellings (townhouses) not more than three stories in height with a separate means of egress and their accessory structures that are in accordance with the provisions of the 2003 International Residential Code portion of the 1999 State Building Code.
In general you are correct. However I have seen a few municipalities where the enforcement of energy code, as it relates to lighting, does fall upon the electrical inspector.Originally posted by pierre:
"Why can't things just be simple? "
Peter
If they were simple, anyone could do this work and we would not be professionals![]()
Yes there are energy codes that need to be followed, but they are not the electrical inspectors field work inspection for type of compliance. A professional licensed Engineer has to stamp the prints with his seal to say he has performed the proper calculations, and designed the building accordingly.
As an inspector, I would not even know where to begin to take the readings, how many readings and at what time of day, etc...
No, residential lighting is not covered. As I said earlier, all the mini-mansions around here have dozens or incandescent recessed lights, 10 seer air conditioners, landscape lighting, pools, hot tubs, the works. Hardly energy efficient. :roll:Originally posted by cselectric:
Peter, I also noticed that CT enforces the IECC. I'm not sure if that has any reference to residential lighting as I don't possess a copy of said code.
Where does the NEC require a luminaire?Originally posted by allenwayne:
There is nothing in the nec that gives us a min. candle power.Just says there has to be a luminaire in the room either direct ceiling wired or a switched wall receptacle
