FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
Depends on the time period, and on the phase offset between V and I.
In other words, the power delivered is (V^2 / Z) * cos theta. That is also the rate of work required.
Cheers, Wayne
0<PF<1, take whatever period you need to express it in terms of energy per coloumb since both watts and amps have common denominator.
as for the work required, you can verify cos(Φ)V2/Z when you have the math for J/coloumb
i believe physics says you need more work to increases amps when volts remain constant. this does not agree with cos(Φ)V2/Z.
