Section 520 what is everybodys thoughts.Are GFCI's required in dressing rooms above counters?I do not think they are.
Is there a sink near by ?
Just a sink won't invoke a requirement for one.![]()
Presuming by "above counters" you mean the dressing table counters, you are correct: no GFCI is required. But those receptacles must be switched, and the switch must also control a pilot light outside the dressing room door. That allows the night security patrol to discover that an actor may have left a curling iron plugged in (and still heating) at their dressing table, without having to open the dressing room door to look.Are GFCI's required in dressing rooms above counters?
Are you sure. Does the code say the sink needs to be connected to plumbing ?
I forgot to include a code reference. This comes from 520.73. Do you already have this feature built into your design?But those receptacles must be switched, and the switch must also control a pilot light outside the dressing room door.
I do not believe they are required.Electrical eng. seems to think they are required.I am waiting for his response.
