Re: Theres some funny stuff going on in this kitchen!
By Charlie: However, it doesn't say you can't add to the circuit or that you are limited to just one receptacle outlet. This says to me that you can have a receptacle outlet for the washer and also install an additional receptacle outlet on the opposite wall for the iron.
I can't see that the ironing receptacle has to be on the same required laundry circuit, and I don't see where you can't supply additional receptacles off a general purpose circuit for other for other equipment.
Putting the ironing receptacle on with the washer and or dryer circuit could cause problems. We have put a general purpose circuit receptacle in the laundry room many times for using a vacuum or radio even a TV. as long as it is not on the laundry circuit.
I think what he has would be a very hard call to go back on the original EC. And as AL pointed out if the Dishwasher doesn't draw over those wattages it wouldn't be a violation, maybe not the best design but that's not the NEC is about.
But this does bring out about one thing that I have noticed around here is I have gone back on a few houses that passed inspection and find many (not allowed appliance's) on the SA circuits. I just don't think this is one of the areas that gets checked often. some of them are ice makers, micro-mates, dishwashers, compactors. As these should not be on the SA circuits.
And I do have a problem I think needs to be address with UL as to allowing these peak values for wattages on appliances as I just had a air compressor that boasted a 5hp rating but only had a 15 amp cord, The inspector told me I had to have at least a 40 amp circuit as it would draw over 31 amps @ 120 volts. I tried to get him to understand that these ratings are some kind of peak rating and not the actual true rating. I had to have the home owner remove it until after the final. :roll: The problem is even on the motor there is no amperage or true HP as it just says special.
