peter d
- New England
I can't think of any reason other than to keep some lights on if a fault occurs...I'm just trying to reverse engineer what I saw to determine what was and what wasn't.
I have never done a WalMart but I have seen a base open and all I saw were wirenuts sticking out...no fuses at all.
on the blue box lights they had them fed with a 3 pole breaker i think 3 poles to a circuit. each pole had 3 heads wired a-b, b-c, c-a. then of course thier security circuits here and there.You really think the 3 heads on one pole are on seperate circuits?
Maybe one here and one there, as night-lights for security between midnight and 5AM....
Besides the shock hazard there is also the danger of lamp breakage. Seems pretty foolish to be removing live HID lamps that could very well be frozen in the sockets, but that's just me. How hard would it be to take inventory of the dead stuff by putting a piece of tape at the bottom of each pole with a dead lamp, then killing the power?
I just kinda shook my head and saw in real life why we have so many statistics about electrocutions and injuries. There was no justifiable reason to do any of that work live, other than perhaps they might get to leave the job an hour early from the time saved to walk back and forth to the electric room a few times. :roll:
Thers old electricians and bold electricians, but there are no old bold electricians.:smile:That is just sad....
The electrician that doesnt respect electricity, never gets to become an old electrician.
~Matt
FWIW, some newer HIDs I've worked on have a nylon disconnect inside the fixture. The supply end is mounted on the back of the fixture towards the pole. Pull it apart, and all the hots/neutrals are disconnected. It's possible their fixtures have those as well, and they're really not working them hot.
I was at Home De....errrr...I mean the orange box today and saw one of our large New England based EC's doing lighting maintenance on all of the outdoor parking lot and facade lighting.
Nothing out of the ordinary except they were changing all of the dead lamps and ballasts out live. I'm guessing they over rode the energy management system because everything in the lot and on the building was lit (except for the dead stuff of course.) One guy had a ballast taken out of a pole light with the other 2 heads lit and another had a wall pack hanging by the wires. The poles are likely 480, wallpacks are likely 277 volts.
I worked with a older electrician that did this in a maintenance shop, and he got shocked via his hands too far down on his Ideal strippers, and got into 480 or 277 to ground I should say.....any way it rattled him pretty good, pulled muscles in his shoulder and neck, had to have physical theropy for a few days....hurt him pretty bad.....DONT screw around with 480 period....
