Could someone explain how overtorquing a device screw can cause a connection failure? I understand that you can overtorque it enough to cause the screw to fail or strip out, but that would be obvious at the time of making the connection.
Thanks, Wayne
You can crush the wire so severly it distorts it and the connection between the conductor and the lug/screw can be compromised. On a simple device such as a switch or receptacle, you can physically break the parts.
