sokkerdude
- Arkansas
Is there a standard torque spec for lugs according to there size? Or are they according to manufacturers? I have a 3000 amp transfer switch with the lugs
so close together that i barely get a "L" 1/2 in Allen wrench in to tighten them. How does one torque them to specs if you can't get a torque wrench on them? If I remove a set of lugs to be able to use a torque wrench, do I blow the manufacture warranty on the transfer switch, if any thing was to go wrong. Thank you
