towel rack
can a heated towel bar be installed in a tub enclosure? the towel bar is 120 volt gfci protected. would it be required to be ul listed for this application?
What do the instructions with the towel bar indicate?
mdshunk said:
I've never seen a resi one that didn't plug in, so I'm not sure how you're going to compliantly get a receptacle in a shower.
Weird, I've never done one that came with a cord. and i''ve done more than a dozen of them. they were all non US made, and came with a utility box cover.
Then no GFI protection would be needed.
i've installed hard-wired towel warmers; they were all listed for damp locations, but not wet locations. directions also specified gfci protection.
water,GFCI
water,GFCI
Wouldn't the towels stay wet if they were inside of the tub enclosure? I guess I am having a visual issue here. Electricity, No GFCI protection and inside of a Tub enclosure, Hummmmmmmm I am having a real issue with this. I would read the manufactors instructions and warning and installion instructions, If it is not UL or third party tested, I wouldn't recommend it.:-?
i've had customers request it in those large open built-in showers. but again, all the ones i've done say 'damp location' and not 'wet location', so i wouldn't install it within the footprint of the shower.
No, It wouldn't be prudent.
Who wants to use a hot wet towel.
Is this in the red light district?:D
