electric776
can a heated towel bar be installed in a tub enclosure? the towel bar is 120 volt gfci protected. would it be required to be ul listed for this application?
electric776 said:can a heated towel bar be installed in a tub enclosure? the towel bar is 120 volt gfci protected. would it be required to be ul listed for this application?
mdshunk said:I've never seen a resi one that didn't plug in, so I'm not sure how you're going to compliantly get a receptacle in a shower.
stickboy1375 said:Weird, I've never done one that came with a cord. and i''ve done more than a dozen of them. they were all non US made, and came with a utility box cover.
480sparky said:Then no GFI protection would be needed.
iwire said:What do the instructions with the towel bar indicate?
Wouldn't the towels stay wet if they were inside of the tub enclosure? I guess I am having a visual issue here. Electricity, No GFCI protection and inside of a Tub enclosure, Hummmmmmmm I am having a real issue with this. I would read the manufactors instructions and warning and installion instructions, If it is not UL or third party tested, I wouldn't recommend it.:-?electric776 said:can a heated towel bar be installed in a tub enclosure? the towel bar is 120 volt gfci protected. would it be required to be ul listed for this application?
http://www.ambatowelwarmers.com/jeeves/pdfs/installation_instructions_10-05_rev2.pdf Here are some instructions from one manufactor.electric776 said:can a heated towel bar be installed in a tub enclosure? the towel bar is 120 volt gfci protected. would it be required to be ul listed for this application?
Inspectorcliff said:Wouldn't the towels stay wet if they were inside of the tub enclosure? I guess I am having a visual issue here. Electricity, No GFCI protection and inside of a Tub enclosure, Hummmmmmmm I am having a real issue with this. I would read the manufactors instructions and warning and installion instructions, If it is not UL or third party tested, I wouldn't recommend it.:-?
Your welcome, glad to help.electric291 said:Thanks for the jeeves website. It was very helpful
