Yes. No disagreement with that.where does the sqrt2/3 come from? How is it derived?
i know for a diode rectifier 3 ph
Vdc = 3 x sqrt2 x Vll ac rms / Pi = 1.35 Vll rms
But my point was about current.
Powers a VFD for a motor (see details below)I agree. (Depending, of course, for what purpose the DC supply is intended.).
^^^^ i was thinking the same thing hahaRated dc v is +/- 0.01% of full scale
for 330 vdc +/- 33 mV
that is tight
better be for $20k lol
So I have a question about your setup in general. You are feeding a VFD with the DC supply. Why? The VFD can have its own rectifier built in, so all you would need is a transformer ahead of it on the test bench to be able to feed it 208VAC from whatever your line source is. This seems overly complicated to me. In fact you could probably get away with using one transformer, sized for a 480V input, then when you feed it 600V, the secondary would be 260VAC feeding to the drive, which is well within the drive input voltage tolerances. Then you have the drive programmed to output 208VAC to the motor regardless of the input voltage.
I have an up-front consultancy fee......................but how is the sqrt2/3 factor derived?
I have an up-front consultancy fee......................![]()
smart man lol
I do the same
is there a friends and family discount?![]()
I can be bribed.....
A little off topic tale that might amuse - mods be kind...
I got a call from my son.
"Dad, would you like to have Sunday lunch with us?"
"OK. When did you have in mind?"
"This Sunday."
Check with wife.
"OK. That's good with us."
"What do you know about dimmers?"
"I might know something....."
The long and the short, we purchased the parts, I did the repair, and we had a superb lunch. I think we got the better side of the deal................![]()
Irish stew - his lady is Irish - but made with the best cut of steak.Lol
That's what dads are for
especially when they have highly sought after and expensive skill sets
at least you got a good meal out of it lol
Take a simpler path solving things. Basically, your DC-fed inverter will have losses and the AC amps input will just be the VFD output plus losses translated into AC. The usual practice is to always use the least possible AC voltage you can get from your source, here, if it's 480 volts AC, use 480 x 0.95 = 456VAC.everything about this project is overly complicated!!! You should see the controls portion of this, twice as bad as this power section! haha
basically this test bench needs to be abe to run off of 3 diffferent 'Shop Supply' voltages , depending on what they are testing. it coule be 600V or 480V depending what country they are in to power the Power Supply, or they can use the 208VAC to test the motor only
it will typically run on 480VAC(use the 600to 480 XFMR when in Canada) to power the 330VDC Power supply.
this 330VDC power is what they typically use on the train(so they tell me?) , and this i really what we are trying to replicate. they Transformer and 330VDC Power Supply are used offline in their shop (not on board the train)
the VFD and Air compressor are typically mounted onboard the train doing their job, that is until they malfunction and then they will bring it to this 'Test Bench' in their shop for testing of the VFD and/or Air compressor
The 330VDC (supplied by the train) powers the VFD which powers the air compressor motor
they are using the 330VDC directly to the DC Bus on the VFD b/c they simply do not have 3-phase power available to them to use onboard the train. I didn't even know this was possible but the VFD people tell me that this setup works, just not a typical installation obviously...?
Where doesthe 0.95 Come from in your voltage calculation?if it's 480 volts AC, use 480 x 0.95 = 456VAC.
Lemme try:
AC amps input = (91A x 330VDC)/(456 x 1.732 x 0.69pf x 0.87eff) = 63.34 amps AC. That's a 50kVA transformer, 3-phase for you, at a minimum.
It's basically trying to factor in a 10% variation of the supply voltage +/- 5%.
So I have tried to avoid that and ordered a multi tap Transformer, so my output voltage should be pretty damn close to 480, do I need to account for that 5%
