jayrad1122
- Northeast, PA
tonyou812 said:jay are you a leffty?
why yes I am :-?
edit: was it the drill that made you wonder?
bakerbrotherselectric said:If someone knows the code section for requiring a bond bushing at what voltage, it would help.. I thought it was 250v and over , and going through a concentric knockout.
bakerbrotherselectric said:I read that section, which made me wonder why the bond bushing was on the 120/208v sec. According to that section and my understanding of it, the bond bushing should be on the 277/480v primary. ????
This would not be the first time my understanding of the code would be wrong, please correct me.
jayrad1122 said:why yes I am :-?
And the xformer cover is screwed on the left side of the xformer. We dont miss much do we???? clip on the screwgun is on the right side ect.....ect..... screams LEFTY!!!Huevos said:Not sure what made him ask the question but, being right handed, I always hold the strap with my left hand and drive the screw with my right on a vertical run. Your screw hole on the one hole strap is on the left.
Good point, never thought of that. Missed the clip on the drill motor too (even though the OP mentioned it). Guess I need to sharpen my observation skills....peter said:Eggs,
Perhaps the stud behind the drywall is on the left hand side.![]()
~Peter
You can always unbolt the lugs from the transformer, hold them with channel-type pliers while you tighten them, and then re-install them. It's better to not put that strain on the winding conductors anyway.jayrad1122 said:I don't know how other transformer are but I didn't like how the lugs only faced the side, it would have been easier if they were facing forward.
LarryFine said:Nice work! Be proud.
I noticed how close each phase's primary and secondary lugs are right away. I would have put them on facing away from each other, which is easy if you remove them to make them up anyway.
mivey said:It is hard to tell, but did you use Belleville washers, and in the 3rd picture (lug on right), is a Belleville washer installed next to the busbar, or is it an optical conclusion?
My life is complete!!!:smile::wink:jayrad1122 said:Ohh and my No-Dog was waiting for me on the side of the panel this morning![]()
Ragin Cajun said:Nice. Be sure to keep the transformer off the wall 8-10" depending on manuf instructions. 50% of the cooling is out the back vents. Too often I've seen transformers slam up against the wall.
RC
roger said:Some new transformers are only requiring 3", I know this to be the case with SQ D.
Roger
Roger
It would appear you have an aluminum to aluminum connection made with steel bolts. The disc-spring washer (Belleville washer) helps to maintain a constant pressure on the joint. The aluminum and steel expand at different rates and when the joint heats up, the aluminum becomes stressed and is deformed (undergoes plastic deformation).jayrad1122 said:I have no clue what a Belleville washer is. Care to explain:-?
mivey said:It would appear you have an aluminum to aluminum connection made with steel bolts. The disc-spring washer (Belleville washer) helps to maintain a constant pressure on the joint. The aluminum and steel expand at different rates and when the joint heats up, the aluminum becomes stressed and is deformed (undergoes plastic deformation).
