Just considering the physics, I don't see any way to check the winding direction other than checking the leakage field - as done by both your compass or gar's hall effect xdcr.
Or a Mag-Probe. I wonder how many other devices could do it ?
Okay test to see if I have this right:
Case 1 - Additive
Orient the core so we are looking down one arm, along the axis of the windings.
Starting with H1 close to us, wind clockwise to the other end of the arm - label H2.
Starting again at the end close to us, label X2, wind CCW to the other end - label X1.
X1, H1 are the same polarity, xfm is called "additive".
Case 2 - Subtractive
Starting again at the end close to us, label X1, wind CW to the other end - label X2
X1, H1 are the same polarity, xfm is called "subtractive".
It would be best to actually wind yourself a crude transformer or two & experiment as we did. Core loss was horrendous.
I think this also follows $S's post:
Smart linked an excellent PDF. Many transformers have opposite &/or adjacent terminals for physical reference.
I've got a 4-ch isolated input scope. I can tell the polarity but not the winding direction - same as I could with a volt meter. Bes - is there something I'm missing here?
I think he was just thinking of detecting polarity, not winding direction. This question was unusual.
I'm curious as well. I can see how this could matter to an mfg - they want to produce the best product (actually - the best looking specifications) they can for the minumim money. But why does this matter for the end user? If the xfm has the required specs, accuracy for an instrument xfm or losses for a power xfm, why would the winding direction matter?
ice
