- Massachusetts
Hi all, a friend of mine went on a call for a loud transformer.
It is a K rated 480 delta 208Y/120 transformer, I do not know the size, probably 45 to 75 KVA.
Here are the true RMS readings he got.
Primary
A-B 496 volts
A-C 497 volts
B-C 497 volts
Secondary
A-B 214.8 volts
A-C 214.7 volts
B-C 213.9 volts
Primary
A 15.6 amps
B 18 amps
C 21 amps
Secondary
A 2.4 amps
B 21 amps
C 5.4 amps
N 13.7 amps
I have confidence in my friends ability to use his high quality meters.
He would like to know if these readings suggest any particular problem, something more than 'it's junk'.
[ December 26, 2004, 11:02 AM: Message edited by: iwire ]
Primary
A-B 496 volts
A-C 497 volts
B-C 497 volts
Secondary
A-B 214.8 volts
A-C 214.7 volts
B-C 213.9 volts
Primary
A 15.6 amps
B 18 amps
C 21 amps
Secondary
A 2.4 amps
B 21 amps
C 5.4 amps
N 13.7 amps
