Transformer Wiring
No
HAMMOND POWER SG3C0045KD D16 SNTL-G 3PH 45KVA 480D-240D/120CT AL 60HZ 150C 3R ENERGY EFFICIENT DISTRIBUTION TRANSFORMER​
As DK said, no, that's a delta-delta unit. The center-tap, if grounded, creates a high-leg.
What voltage and system type are you looking to obtain, and what voltage do you have?
You would only connect a wye's primary neutral to the source if you had a wye secondary.
I have 480 wye with no neutral. I need 240 3 phase.
on an existing system it is 240 delta. it runs the pneumatic pumps on flour trailers. so that is why i was saying i need 240 delta
would 240 wye work? i know i wont be able to use any single phase off of it but would it work
Then you need not ask about a primary neutral.
I need 240 3 phase.
Absolutely, and having the wye secondary would make grounding it simple.
Otherwise, you would have to ground the center tap, corner-ground, or use fault-detection.
so which one the first one i posted or the wye to wye
He's referring to the delta-delta you posted. It suits your source and required voltages.
But it doesn't make for symmetrical grounding. Ideally, you want a delta-to-wye transformer.
And, yes, they are common. So, look for one with a 480D primary to 240Y/139 secondary.
If you want 240 line to line on the secondary, and want a grounded system, you will have to make it corner grounded, get a transformer with center tap so you have a high leg, or get a drive isolation transformer with a 240Y/139 volt secondary.
And, yes, they are relatively common.
Yes a secondary of 208Y/120 is very common, but if he needs 240 volts line to line, a secondary of 240Y/139 is less common.
I want 240 line to line. I don't care if it has a high leg or not. If I pull 120 off of it I will just be careful not to use the high leg.
can I use a delta to wye transformer on my 480 wye primary? i think i have before
If i can use the first transformer i posted then thats what I will do. the symmetrical grounding im not too familiar with
Yes, it will work, and if you might have use for the 120v or 120/240v, then definitely.
Bond X0 to your building's electrode system.
By symmetrical, I meant equal line-to-neutral voltages, like a wye normally has.
You're welcome.
To recap:
The primary will be the three lines plus an EGC; no neutral.
The secondary will be three lines (one hi-leg) and a neutral.
