gutierrjg said:Hi,Guys I'm trying to fix a residential gas oven.When open the gas the ignition should give me some signal but nothing happend.Could someone give me some advise how to check this.
Thanks
do you hear it arcing when you turn the knob?gutierrjg said:Yes it has,but how can I read if the igniter is receving power.Any idea?
thanks
im pretty sure if the ignitor has a problem, it wont allow the gas to flow. replace the ignitor module and see if that works. im probably wrong since im not an expert of gas rangesgutierrjg said:Nothing.I'm here is my comfusion.No gas no,no arcing.which one depends of the other?
i dont like to mess with gas either. i would personally call a repair man for a gas oven since it kind of scares me a little76nemo said:The oven will receive a mV signal that the pilot is engaged. I won't add to this any further, as I am a FIRM believer that one should NOT mess with an appliance that requires gas to operate. An electrician, and an appliance tech. are two different technicians.
Are you COMPLETELY confident to sign off on such a repair???
gutierrjg said:Ok,I'll start all over again
Thank,very helpful
gutierrjg said:yes I am,There is not any problem if one turn off the gas.
