Trying new program on a home build does this seem high
We should be the last trade or there at same time as hvac. Plumbing goes first always.
Doesn't work that way. They want the electrical in so they can use their tools, and then they make installations that violate NEC and then just say: "it's your problem, because it doesn't violate plumbing or HVAC code."
Seems to me they should know NEC when it interacts between their systems and the Electrical and be made by their respective codes to comply with NEC.
Company I worked for back in the '90s, we would install the heat cable. But they weren't using that orange mat back then. We had spacers and we had to screw them down on the floor. It went inside of a mud bed.
I seen one guy that cut grooves into his substrate and lay the cable in that then put an epoxy coating over the entire substrate before laying tile over it. He tested integrity of cable at different stages of the install to make sure nothing happened to it. He claimed he would warranty his install and had the ability to find a break down the road and repair it without major destruction of the floor.
Any tile systems won't honor material warranty in that case
You get the other companies in the region to just say no. Throw your weight and make them do it right. Include it in your paper contract
I don't know details of his warranty, I imagine probably will repair for free for a minimum time period if deemed product or installation defect. Point was he was pretty particular about how he installed it and careful to test at different intervals of install to assure nothing was damaged, while still having opportunity to fix it if it were before finished.
Door swings
(Electrician put switch behind door)
Sheetrock covering receptacles
Rotozip mangled wires
Appliance garages (not on plans, cabinet maker suggested) covering 1/2 receptacle box
If these happened rarely might be tolerable but seemed like every house
I don't miss it
I am mostly wondering if my labor units are off or if I just charge to much per hour.
Labor Units Breakdown (McCormick Equivalent)
TaskQtyMcCormick Labor Units (Hours per Unit)Total Labor Hours
Receptacles (50 total)500.3517.5
Light Fixture Wiring (32 locations, not installing fixtures)320.5517.6
Switch Wiring & Installation (22 switches)220.357.7
Main Service Panel & Subpanel Wiring22.04.0
NM-B General Circuit Wiring (28 circuits)283.8106.4
Dedicated Circuits (Water Heater, Range, Dryer, Heating System)42.510.2
Light Fixture Installation (Standard Ceiling Fixtures)200.612.0
Light Fixture Installation (8' Garage LED Strip Lights)41.04.0
Outdoor Light Installation80.756.0
Total Labor Hours--
185 total hours
How are you applying rates to the 185 man/hrs?
