Turns ratio of a transformer is Pri voltage/sec voltage or N1/N2. If we are not told which one is Pri and which one is secondary. Let's say you are just given it is 240/120 transformer. The transformer can be used as step or step down. How would you know what is turns ratio in this case?
If I take 240 primary then a= 2
If I take 120 Primary then a= 0.5
