I do, but I don't use wire nuts. I use Buchanan crimps, and this is how I do it.
That is one heck of a twist on the grounds.
That's nothing. I can get them off and put them back on again.It took awhile but I finally learned to get those crimp splices back off if I need to. It's not fast and it's not easy but it can be done with a sharp set of tin snips. :grin:
how bout some of you twisters explaine why you do it?
That's nothing. I can get them off and put them back on again.![]()
I am a twister and use both mostly greenies and ground crimps resi. Commercial I use mostly reds and ground tails (Boss thinks you are trunkslamming if you buy greenies in comercial) to the box try to use self grounding devices where I can. I have seen more contractors using wagos more often and I am not as against them as I was with the first generation wagos. The newer ones seem to make a solid splice.How many of you twist your bare ground wires together in the outlet boxes? How many of you use red,yellow and greenies wire nuts in residential wiring?
That's nothing. I can use one for an entire house inspection, and do the same thing again on the next job.That's Nothing. I can get them off after inspection and use them on the next job.![]()
They didn't really see a reason for it, and code rule aside, I would be willing to bet that there is no real difference in the electrical quality of the twisted only connection and one with a wire nut or crimp.So what's wrong with a simple wire nut? :-?![]()
