Ken, you are still confused, let me give you a simpler illustration and you can take it from there. I would suggest you go to the test bench if the following illustration doesn't help you understand the theory.
Both sides of the circuit are identical as I said before in post #28, you must have missed it. :roll:
Both sides have a grounded and an ungrounded conductor.
Hope this helps.
Anyways, if it doesn't help, don't worry about it, parallel OCPD's are only allowed in factory assemblies so you probably won't be affected by it in field installations. :wink:
Roger
Hope this helps.
Roger
