- Massachusetts
Re: Two Pole Switches Used to Control Two Different Circuits
However you may not have more than 300 volts between two separate devices in the same box without a divider.
That is not a violation, you may switch a 480 volt load with a properly rated two pole switch.Originally posted by thinfool:
Another aspect, if I remember correctly...you cannot do this if you are supplying 277 volt lighting. It would mean 480 would be present within the switch housing.
