david
- Pennsylvania
Once an exception to more than one service allowance is met, there is no code violation in relationship to the location of the service disconnects, no matter how far apart those disconnects are located from each other
Both service will be required to bond to the buildings grounding electrodes to establish a grounding electrode system.
In this particular thread it has not been explained why two services are being (designed) installed,
it may be possible to redesign and install one lateral to the building in with a line side tap for the fire pump to a location for the pump service disconnect
Without using arbitrary enforcement of objectionable current there is no code violation
