why wouldn't it be? it is only required to be supported and secured. nothing in the code says how that is to be done. Tie wraps are a very secure way of securing things.mattt said:I have an electrician doing some work in on of my buildings he ran the 1" emt on the bar joists and than used a tyrap to secure it
I dont think this is per code do you ?
JacksonburgFarmer said:What about "Workman like installation".
"Workman like" is only in the eye of the beholder, there is no absolute definition of what "workman like" is.JacksonburgFarmer said:What about "Workman like installation".
I like the way tie wraps look versus clamps.roger said:"Workman like" is only in the eye of the beholder, there is no absolute definition of what "workman like" is.
Roger
bbaumer said:The only problem I see is that tye wraps can get brittle over a long period of time in certain environments. Probably will never have a problem even though it looks cheap.
Well without knowing the building there maybe skylights in the vicinity.iwire said:Not much sun exposure in steel bar joists.![]()
cschmid said:I believe we need to look at what the tyrap is list for and what the amount of weight the tyrap can handle..I personally would not use that method even if the customer tried to beet the price into the ground..I believe the tyrap is only rated for 15lbs but I can not be sure as I am not going to research it right now..
nakulak said:if the bar joist is supporting the weight, what difference would that make ?
kjw444 said:Well without knowing the building there maybe skylights in the vicinity.
