jrannis
- Fort Lauderdale/ Miami
I use tywire, You cant see it from the ground and it can be tied very tight
jrannis said:I use tywire, You cant see it from the ground and it can be tied very tight
hardworkingstiff said:What's all this talk about demo? Do you really do that much of it?
Plus, your bid may have taken into account reusing all the straight pieces of pipe and some or all of the larger conductors. I know I often figure that way. A demo contractor is going to have all that taken to recycle faster than you can whistle Dixie.iwire said:We do a fair amount of electrical demo in commercial tenant remodels. You can't let the regular demo contractors go nuts in a building that has other tenants.
I disagree:crossman said:See 358.30(B)
The tie wraps are not even needed. The EMT can be simply laying on the bar joist... except the EMT has to be securely fastened within 3 feet of boxes.
358.30(A) Securely Fastened. EMT shall be securely fastened in place at least every 3 m (10 ft). In addition, each EMT run between termination points shall be securely fastened within 900 mm (3 ft) of each outlet box, junction box, device box, cabinet, conduit body, or other tubing termination.
George Stolz said:Right, (B) says it can rest on the joist, but (A) requires it to be fastened to it as well, no?
iwire said:But IMO the way it is written I could argue it applies to trusses. :grin:
Flex said:i came on this forum to learn more about electrical, and different ways i can improve the way that i do things.
anyone who tye wraps pipes is a shoemaker and gives all electricians a bad name.
my boss would fire anyone who tried that crap.
hed rather spend more time and money and have it done right.
there is no opinion involved here, it is a fact that tye wraps are the cheap cobbler way of doing things.
Flex said:i came on this forum to learn more about electrical, and different ways i can improve the way that i do things. anyone who tye wraps pipes is a shoemaker and gives all electricians a bad name. my boss would fire anyone who tried that crap. hed rather spend more time and money and have it done right. there is no opinion involved here, it is a fact that tye wraps are the cheap cobbler way of doing things.
Flex said:i definetly am learning things but im not impressed that someone would think nothing of doin crap work
iwire said:Dude get over yourself, your opinion is just that, your opinion.
As long as it meets code all other issues are between the customer and the EC.![]()
