cschmid
- Northern cold country
Smart $ said:If that's the case, why not just use reinforced strapping tape, such as 3M Scotch Reinforced Strapping Tapes...
It is inexpensive :wink: and with tensile strength up to 240 lbs./in. width, you could even use it to support conduit to the bottom of trusses (2 wraps x 240 lb strength of 1-inch-wide 865 = 480 lbs.)![]()
I dont see any where it says you could not use it..Bob opens up an interesting point about what is securely fastened into place..tyhe tape would securly fasten it into place..so does the tie wire..my question would be what is the life span of a ty-rap in an area where the ambient temps are 100 degrees or better..what is the life span of tape in that same inviroment given the 3 choices tie wire is the better of the three..Ican see the savings..so how does in a workman like manner play into it..is it the customer, the installer, the AHJ or who decides what is a workman like manner..so many questions...
