Can a 12/2 UF cable directly buried be used to feed a pool pump motor?
The way I interpret the code the answer is no.
Electrical inspector says it’s an approved install using it.
I read it as being limited to use within buildings.
Column I’m using is
Pool associated motors: from branch circuit OCPD to motor.
Thanks
Column I’m using is
Thanks
