Let's settle this :huh:
Only the ungrounded conductor is shown for simplicity.
The only thing close to a definition of parallel conductors in the NEC is AFAIK in 310.10(H)(1)... "electrically joined at both ends".
Pick any two wires A thru E. Are they electrically joined at both ends?
Additionally, let's say each wire is contained in a separate raceway or piece of cable. If a load is connected to any one receptacle, is there circuit current on each piece of wire? (Yes) So if you have circuit current flowing in say B and D, how does this meet Code for all conductors of the same circuit to be in the same raceway or cable?
No.... are the conductors in a "ring" circuit "parallel conductors" as per the NEC requirements..,.
Yes.or are they just simply segments of a circuit that happen to be parallel paths to one another?.
There you go. If you are not trying gain a greater ampacity then there is no non-parallel rule.An NEC compliant and intended "parallel conductor" is smaller sized than the circuit design ampacity, and multiple conductors are joined together to effectively make one larger conductor.. .
Where does the NEC say that?...There you go. If you are not trying gain a greater ampacity then there is no non-parallel rule.
There isn't much choice if you run flat twin and earth.
The conductors are all within one sheath.
Pic of this stuff:
...excepting insulation and sheath colors.That looks like what we call that NMS (Non Metallic Sheathed) cable, or 'romex'.
Yes. A brand name.That looks like what we call that NMS (Non Metallic Sheathed) cable, or 'romex'.
Yes. A brand name.
The point is that live and neutral run together in close proximity.
It's routinely used here for 230V single phase for residential and commercial.Is that cable run in just about any location?
Here NM cable is mostly only run in dwellings, and using it at all is prohibited in some locations.
Yes. A brand name.
Neutral is Blue in Europe.What color is the neutral?
Live is brown, neutral is blue and the earth, if an insulated conductor, is yellow/green.What color is the neutral?
If I were there my opinion would be go ahead and mess with the phase colors all you want, but leave the neutral and ground alone. At very least do not use an old neutral or ground color as a new phase conductor. Then again maybe their intention is to kill off those that don't know any better but still choose to mess with wiringLive is brown, neutral is blue and the earth, if an insulated conductor, is yellow/green.
The three phase colours changed a few years ago to "harmonise" with EU land.
A totally unnecessary and insane act of monumental stupidity in my opinion - and that of many others.
It used to be very simple. The three phases were the three primary colours, red, yellow, and blue. Neutral was black.
Now brown, grey, black and blue for neutral.
Bureaucracy gone totally bluddy mad.
The ground (earth) stayed the same. That's the only redeeming feature of the imposed totally idiotic changes. By the EU.If I were there my opinion would be go ahead and mess with the phase colors all you want, but leave the neutral and ground alone.
A somewhat off-topic rant but somewhat related to changes imposed on us by the EU.
My uncle ran the croft on the western isles off the NW coast of Scotland. A few hundred acres and not very demanding of his time. He had a full time job as borough surveyor looking after roads etc.
Also, not terribly demanding. He got a decent salary for the job. But he made much more out of agricultural produce at prices fixed by the Common Market (the predecessor of the EU) and guaranteed sales for them. Whether or not there was actually a demand. And subsidies based the number of livestock, crops..... As did many other farmers.
In accordance the common agricultural policy, CAP, which consumed the bulk of the costs of membership contributions.
The inevitable happened. The Common Market ended up with huge surpluses of milk, butter mountains, wine lakes....and stuff.
It took twenty years for the bureaucrats to admit that it was an enormous co(r)ck up and do something about it.
The solution almost breathtaking. The farmers wouldn't/couldn't continue in business without the subsidies for producing more stuff than anybody wanted.
So they got subsidies for NOT producing stuff.
We now have to deal with wire colours that nobody wants, are potentially dangerous/fatal.
I'm pretty sure that if a referendum on continued membership of the EU was put to the electorate it would get a resounding no vote.
Rant over.
Yes, it is all part of the same conductor. If not, then I could just add a splice box to a paralleled set of conductors and declare they are no longer parallel. The connection at the receptacle is no different than having a wire nut or splice and dividing the conductor into segments with splices does not mean this is not a parallel feed.Pick any two wires A thru E. Are they electrically joined at both ends?
What about for voltage drop concerns? Are you saying we are then free to parallel conductors?If you are not trying gain a greater ampacity then there is no non-parallel rule.
Quite.We didn't learn here either, we have subsidies for not producing stuff too. We are running fast towards what the Europeans have already figured out doesn't work.
I don't want bl00ddy politicians telling me what colour wire I have to use.
