coulter said:We have some that are vehemetly opposed to symetrical comments, vectors, and rotating magnetic fields. I agree symetrical components will handle a general case better than most other methods. With the advent of calculators that will handle matrices(sp) and complex math, the method is much easier to apply.
carl
Now Carl,
It is not a matter of being opposed to symmetrical components. It is a matter of keeping the solution simple. My understanding is that this method is more or less required for problems involving rotating machinery, however it is too cumbersome and laborious for static problems. [Paraphrased from Kercnher & Corcoran, "Alternating Current Circuits", Wiley, 1951.]
Nor is it a matter of being opposed to phasors/vectors which will provide a solution just as accurate and is far easier to understand.
Neither is it a matter of being opposed to rotating magnetic fields because no one wants the motors and generators to stop working. Furthermore, I can see no reason to mention this subject in the calculation of neutral currents.
In practice, the algebraic method suffices for most situations, and it only requires a little bit of arithmetic and a trust in the formula.
In summary, we should fit the tool to the job, or "Keep It Simple!"
