jeff43222
- Minneapolis, Minnesota
I had a call tonight where the homeowner/landlord is being told by the city that she has to add a receptacle to a bedroom in the unit she is renting out. She wants to do this as easily/cheaply as possible, so the plan is to tap into an existing receptacle in the next room.
The existing receptacle is one of the old two-prong ones, and I don't know if there is a an effective ground-fault path as required by 250.130(C). I suspect there is not. So I was thinking that it might be legal to replace the existing receptacle with a GFCI receptacle in accordance with 406.3(D)(3), extend the circuit by adding the new bedroom receptacle downstream of the GFCI, and protect the circuit with an AFCI breaker (Anyone know what modern brand can be used in a Bryant panelboard?).
I have Mike Holt's 2005 "Grounding versus Bonding" book, and on page 216 there's a Figure 250-178 that seems to indicate that what I'm proposing to do would be permissible (except for the AFCI part).
Anyone care to weigh in?
