ptonsparky
Tom
- EC - retired
I've only seen one of these in a factory that is long gone. I know of another but have never worked on it.I do not think every ungrounded system had these, I think in the past they were optional.
Ive done some work on a mill in Prov
I can be pretty much anywhere in Providence in 15 minutes from where I am sitting.
It strikes me funny you have worked so close by.
Perfect! Ill call you next time I need help on a saturday or sunday
I'm actually not there that much, just one friend of a friend I do some work for now and then.
:huh:
If you're sitting at home, I don't see how that's possible. :happyno:
:roll:
Google says 21 minutes to Prov place mall.
I apologize for the exaggeration.
Please let me know where you're working next time so I can report you.![]()
Yeah, but try going anywhere not directly on the highway. It will take a bit more than that.
-480sparky
Still common in the surface facilities of underground miningI do not think every ungrounded system had these, I think in the past they were optional.
Is that because of how much Jack Daniels he has in him?:huh:
Ohmmeters don't like to have voltage applied to them, you sure you meant what you said?another method that you could use to test the voltage is using an ohmmeter. This way you can get an accurate reading if any moderations.
I see he is a beginning apprentice. I was hoping he meant VOM.Ohmmeters don't like to have voltage applied to them, you sure you meant what you said?
How many farmers do you work for that have a cheap $20 analog meter they use to troubleshoot irrigation equipment with, and once in a while have it on ohms setting and connect it across 480 volts? I still see several of these guys and they never learn from that mistake. I try to tell them they need a automatic volt/continuity tester that has no switch, but those cost too much:huh:I see he is a beginning apprentice. I was hoping he meant VOM.
I have one that was using the little neon glow testers. I chastised him multiple times. I finally bought him a Fluke TPro. I considered it a 'seed corn hat'.How many farmers do you work for that have a cheap $20 analog meter they use to troubleshoot irrigation equipment with, and once in a while have it on ohms setting and connect it across 480 volts? I still see several of these guys and they never learn from that mistake. I try to tell them they need a automatic volt/continuity tester that has no switch, but those cost too much:huh:
Seems to me, and considering you are lucky enough not to need medical care after the thing blows up in your hand, the thing will pay for itself after burning up 2 or 3 cheap meters.
