- Massachusetts
I have already screwed on blank covers for 4-squares on the end of an old can can to pop different knockouts in it.
I have done that as well.
I decided to try to see just where the shavings were falling and looked from underneath while drilling when one of the hot shavings went right up my nose. Instinctively, I grabbed my nose and pinched it which just intensified the burning pain caused by the hot shaving now embedded in my left nostril. I quickly released my grip on my nose and blew out the offending shaving but by that point the pain was so intense that my eyes were watering profusely followed shortly thereafter by my nose watering. I had to cease drilling for a few minutes while I regained my composure and wiped the tears out of my eyes with my shirt sleeve.
If I had my way, no panel would have any factory KOs. No Mickey-Mouse-Ears trying to put a 1?" KO between to factory ?" KOs.
.....and while we are at it..... gutter....... you can get it plain, but you've gotta special order it, and wait 3 weeks.....
randy
480 Jr?thank you for this. in honor, i am going to name my next illegitimate son
after you......![]()
That's him!
no, 277v.
one leg of 480.
I have read the labels on many step drills of different makes and no where is it stated that there is any danger of burning the inside of one's nose with the resultant shavings.
You really don't expect for them to put that on the label do you? Then next they would have to put in on regular drill bits...
"Warning if you tilt any opening of your body upperward to the falling hot chips, you might be subject to excrutiating pain"![]()
Take a good look at a new ladder, and see how much square footage is required for all the labels on it because someone did something stupid and sued the manufacturer for not warning them about it.
My favorite is the two on the top..... "Do Not Stand or Sit". I'm happy.... I get to lay down the rest of the day.![]()
Could have been worse if, say, you dropped the drill motor while looking up.:smile:
YOU sir have got to be kidding me. It a joke right?I have had many safety courses over the years including OSHA 10 and OSHA 30 and never once was any potential danger of using a step drill, commonly referred to as a Uni-Bit ever addressed.
A few days ago I was in the process of installing conduit connectors in the bottom of a panel using a Uni-Bit to make the holes, drilling up from the bottom. I wear fingerless gloves at work and was getting annoyed by the falling of very hot shavings being spewed from the Uni-Bit and landing on my hands, sometimes entering my gloves from the finger side. I tried my best to postion my hands in a place free from the falling cuttings to no avail. My assumption was that there should be a pattern of the falling shavings and if I could determine where they were not falling I could place my hands in that location for a more comfortable day at work.
I have read the labels on many step drills of different makes and no where is it stated that there is any danger of burning the inside of one's nose with the resultant shavings. In this day and age of the common practice of attempting to address every danger of every device sold I think that the makers of step drills are remiss in not mentioning the fact that if you place your head under a step drill while drilling with your nostrils in an upward position a possible hazard may exist.
I was working alone as my partner was in another room cutting strut for the job. I told him what had happened while he was gone and was dismayed that he was not there to witness the accident but mentioned some solace due to the fact that he was not very fond of the smell of burning nose hair.
I just wanted to share this with all of you in an attempt to make our dangerous work as electricians just a little bit safer.
