brian john
- Kilmarnock, Va
- Retired after 52 years in the trade.
YA, I do. If a tire shop puts a cheap patch on a tire instead of replacing it, you save money now, but if it blows out on the freeway and you total the car how is that savings ? Cheap is cheap, it is not savings.
"Penny wise and pound foolish".
This is a store, what type of equipment is now at risk, due to a questionable ground? Seeing that the solution in the OP is written in the past tense, it is a mute point. The job is done, to a code minimum. So I guess it must be safe.:roll:
I cannot speak for this building but in MOST commercial establishments.
Posted by me earlier
if there are metal ducts, piping and metal studs, concrete with rebar, metal trusses and/or a drop ceiling, testing the EMT will do little to prove the EMT is sufficient.
EMT is NEC compliant and in use in 1000's of 1000's commercial and industrial establishemnts, by your standard I assume you always use #10 AWG copper on 20 amp circuits? #8 on 30 amp circuits? You pipe all your residential projects? NEMA 3R for all panels and FSS's indoors? Dedicated circuits for every 20 amp receptacle to minimize possible over loadings? Suspenders with your belt? And the list of extra precautions could be as thick as the NEC.
