K8MHZ
- Electrician
That does not matter as the definition of outlet in the NEC does not include a switch. The light or equipment that the switch controls would be an outlet.
I disagree. Lights and equipment are not outlets. Outlets are the point on the wiring system that supplies said lights or equipment. Litmus: If you remove the light, are you also removing the outlet? Can you change the light without changing the outlet?
A box in the wall with wires in it is an outlet if it is a point meant to supply current to equipment and wired as such. If the box is wired for a switch, it's not an outlet.
Until maybe now.....
And, since I know you like to make people think........
We now have to pull a neutral into our switch boxes. This is due to motion detectors (equipment)previously using the ground wire as a return. Does that neutral now make switch boxes outlets? Do they change later from a switch box to an outlet if a motion detector is now installed?
We should get used to this kind of brain exercise. More and more stuff will be invented and sold that fuzzes up the rules.
This is why the code needs to truly be considered a BARE MINIMUM and NOT a design standard. Sure, right now, as far as the NEC's definition goes, unless specified otherwise, a USB receptacle and a 120 VAC receptacle can be considered the same and used to satisfy the same requirements.
I am not saying that it is good practice to use the terms interchangably, all I am saying is that the NEC and the UL consider them the same. So far. That may change in the future. But the changes always follow the products. Mostly, anyway.
