ceb58
- Raeford, NC
He's even less qualified than I previously thought. :roll:
Ok, now can we say the guy is a moron? :roll:
It's bad to be less qualified than a moron
Now here's the conundrum...do you just move on in an instance like this...or do you contact his superior and let him know that he has a bonehead inspector in the field. While in a perfect world I'd personally go with the latter...it would make an enemy of that inspector in the future. We have a guy here in my area that's...shall we say...not that bright. A lot of EC's here know of this guy and once you get the paper with his name on it, you make sure someone "capable" is there for the inspection. By capable I mean at the very least the foreman or journeyman who ran the job.
This might be one of those instances where you just have to let it go, finish the job, get your sticker, and get paid.
Unless you have been given a valid Code reference by the inspector that backs him up, I'd say move forward.
Yes lets all lay down and let an inspector continue in his wrong interpretations, driving up job cost and misleading younger electricians and generally causing problems.
I would contact other ECs and go in mass to his boss, that is, if I was afraid of confronting his boss face to face one on one. But generally if you take the inspector aside and ask him for references or show him the errors of his ways, if this does not work IMO he should be fired, but only after talking to his boss.
Around here if they fail you they MUST cite the code section/article used to fail you. Plus I would even wonder if they make a divider for a metal box. I am thinking the inspector had a bad day.I got dinged on an inspection for putting 12/2 and 14/2 into the same metal box. The inspector said that I needed to have a physical partition between the 12/2 and 14/2 circuits. Unfortunately, I wasn't around for the inspection, and my customer can't really recall exactly what the inspector said. No written tag.
The cables in question feed their own devices and aren't connected. That is, I didn't mix 12- and 14-gauge wire on the same circuit. Certainly, 725.136 tells us that Class 2 circuits can't be in the same box as power circuits, but both of these circuits are 120-volt.
Any idea what the inspector might be thinking?
I think the divider belongs on anything over 300v. Many people dont know that depending on the phasing some 277v circuits can have more than 300vs to a 120v ckts depending on the phasing in the same box.You'd better put a divider or partition between them. Both in the metal switch box and the metal panel they originate from.![]()
Yeah, I've never seen dividers for steel boxes, either.
