- Tennessee NEC:2017
- Semi-Retired Electrician
No, I don't believe it is an issue with the nec if the wiring is non ferrous-- 300.3(B)(3)
Because the wiring is NM cable, 300.3(B)(3) specifically allows the installation that Howard found.This is not a NEC issue.
Ok, the main reason I kept asking about the travelers being run by themselves is this:
I had a customer that wanted a "3rd switch" added to a lighting circuit. So I told him I could do that with a 4-way switch. This was in a partially unfinished basement/garage. The problem was the 2 existing 3-ways were in a finished wall and the wiring ran above the finished ceiling in another room. He didn't want to cut or damage the sheetrock so I had to improvise. I put the 4-way midways of the unfinished area beside a door on a finished wall. I had 14-2 on the truck so I ran 2 sets of cable to the first switch to tie in the 4-way. This left the travelers to the 4-way running by themselves. There was 3-wire ran between the 3-ways, including the neutral. I in effect just extended the travelers. I didn't think much about it until this thread came up, but I don't think it is a violation.
