- Windsor, CO NEC: 2023
- Hospital Master Electrician
George's Buried Vanity Primer:
Looks as though Allied pulled the pictures of their pancakes off the website.
I'd create my own cut-in by flattening the flap from the real cut-in, installing it on the pancake; and using the grounding clips on the face of the pancake to keep the box from going into the wall.
If things went well, then it was solid as a rock. If not, then plan B was the stake and drywall-screw treatment. But with a canopy as large as the example given, the drywall screws can be inside the canopy and still get the job done, often.
Last stand would be driving screws outside the canopy and letting the drywaller take it from there.
I guess what I'm getting at is aim small miss small.
- Set the pilot bit of the hole saw just barely beyond the teeth of the hole saw, expecting the drain.
- Remember the height of the mirror. Look at your light.
- Cut the hole exactly where the light will be.
- Discover the drain pipe.
- Grab the materials at hand: for me, it was all Allied: a pancake, a cut-in, and a couple of their grounding clips.
