iwire said:
I disagree, what your suggesting is ignoring the listing of an item which is a direct NEC violation of 110.3(B).
I think now you are
READING into my posts of what is not there.
Im not suggesting that you ignore the (UL or any other) listing of an item or try to 'violate' the NEC.
What I am SAYING is that the NEC
defined what a 'vending machine' is and to IGNORE that definition and install or use something against that 'definition' is a violation of the NEC (Even though it happens i.e. using a circuit beyond the 80% capacity like hairdryers in bathrooms or those small cords on some other units but we wont go there!!).
Im sure that most 'tags' (not all), listings (UL) will 'comply' with the NEC defintions so that there will be NO conflicts. However I do know that the
MAIN reason that the NEC went through the
PAIN STAKING trouble of defining 'vending machines' is because (in 2005 code 422.51)before there was some
CONFUSION in field concerning that issue of what exactly is a 'vending machine' and that people were getting cited, or had trouble complying with that article.
Some claimed that a vending machine was only a candy or other machine you put money in and get something out . Others claimed that the soft drinks(soda) machines that dispense when pushed (self served) at resturants lobby where you get free refills and you pay at the counter were vending machines and others said no it wasnt.
Some of these examples and (others i do not feel like typing)
do not have a 'tag' or listing specifically saying it is a 'vending machine' but it would be considered as such now by NEC 'definition'. So there was a need to clarify. So that soda machine in the resturant can have a tag on it that says 'soda dispenser' and by NEC definition its a 'vending machine' too, it
does NOT negate or violate the listing/tag of that item.So you are reading into my post of what is NOT there. It just makes it more restrictive.
So my statement
brother said:
I believe since the NEC went thru the trouble of 'defining' VENDING MACHINE, I believe one would have to follow that definition whether it has a 'tag' stating its a vending machine or not to avoid any violation of 2008 Code
Still stands. .
iwire said:
What I would have problem was is an inspector saying a freezer is a vending machine and require a GFCI when the freezer is listed as a freezer and not a vending machine. (Did that make any sense?)
Just to take the 'flip side' of your statement and logic (you read into my posts and i can read into yours)
Lets say the manufactures of the these 'candy/soda vending machines' decides in order to AVOID the extra expense of manufacturing the new machines after Jan 1 2005 with gfci as an intergral part of the attachment plug on the cords, they decide to put a 'tag' or 'listing' on it saying its a 'candy/soda distrubutor' instead of 'vending machine'. Im sure some of these BIG MONEY manufacturers can CONVINCE the UL to go along with it. Would that be okay??? Should this get them out of the requirement of the NEC 422.51 since it is 'listed' as a
'candy/soda distributor' instead of 'vending machine'??
Ok Im done.
