leejersoon
- Singapore
Hi everyone,
I'm not familiar of AC circuits as compared to DC circuits. But someone mentioned to me that I can use the Voltage Divider Rule (VDR) on AC circuits to drop a 240 Vac to 24 Vac by using a high watt 1 ohm resistor and a 9 ohm resistor.
(240*1) / (9+1) = 24 Vac.
I was thinking about it and it kind of make sense. But won't it be up-side-down when the AC current flows from the other way? Then it will become:
(240*9) / (1+9) = 216 Vac.
This will cause the AC voltage to be unstable....right?
Which means for this to work I can only use the resistors that are the same value?
(240 * 5) / (5 + 5) = 120 Vac.
Am I right or did I go wrong some where or is this not applicable at all? :? Thanks.
