propower34
If you had 15 incandescent light fixtures on the same branch circuit equally spaced 10' apart, with the first fixture 10' from the source and the last 150', how would you calculate the voltage drop for each light?
Each light is 100W, 120V, 75 deg.C max. ambient temp., #12 AWG CU.
How is the voltage for each fixture affected by the other fixtures in the circuit, and how is this represented mathematically?
