wago here, wago there....
Fulthrotl
~Autocorrect is My Worst Enema.~
this thread'll probably go everywhere.....
i'm not a big fan of stab back plugs.
left to my druthers, a device should have screw type pressure
connections, and cost about $5. then it's got a binder plate
inside pulled tight by a screw, and enough contact area and
pressure to carry any reasonable amount of current safely.
the stab in connectors that halo provides with their recessed
cans, i cut off and throw on the floor. i use wirenuts instead.
all that being said... my wholesale house handed me a cup of
wago wall-nuts, and asked me to play with them and see what
i thought.
so, with some #12 and #14 stranded thhn, i've been playing
with them this morning, as i'm still a bit under the weather from
stomach flu, and decided to take the day off for a change.
setting aside contempt prior to investigation, my first thought
is that the damn things work pretty well. :mad:
with a 6" pigtail plugged into one of these, i tried wiggling the
wire out, and pulled off the 6" of insulation from the stranded
wire without budging the wire a smidge.
even removing the clear plastic shield from the top of the thing,
you still cannot pull the wires out.
the V shaped metal bus under the grabber plate is heavy enough
to have enough cross sectional area to carry the current, which
is something stab back plugs don't do... there is just that little
metal prong to carry the current. contact pressure is far more
important than contact area, but you gotta have something
more than a bent piece of tin. these do.
tension is enough with #10, #12, and #14 stranded thhn that
you really need to use pliers to properly seat the wire into the
socket. fingers aren't good enough for a reliable connection.
the only thing i found problematic was with #14 MTW, the
stranding twist is greater than on thhn, at least with
southwire product, and it means you have to be more careful
pushing the wire in straight.
what i need is a test bench, so i could put a bunch of amps at
10 or 12 volts thru one of these, and see where it starts dying.
hm. i have an abundant source of current and a clamp on that'll read dc
amps.... a tig welder should do nicely. i'll let you know where they smoke.
after lunch, i'll try bbq'ing some wagos, but at this point,
i can find no fault with them. they work well.
please don't confuse me with facts. i have my mind made up. :D
i *hate* when this happens....
i still have an enormous aversion to stab back plugs. however, the
wagos, properly installed, seem good. maybe the variable in installation
techniques is the reason they have a crummy reputation.
randy
mdshunk
Right here.
One of my bigger gripes about them is that you need to skin the wire pretty accurately. At least with wire nuts, if you skin them too long, you can chomp off the whole bundle to the right length with your pliers. Not much tolerance with the Wago's.
peter d
New England
left to my druthers, a device should have screw type pressure connections, and cost about $5. then it's got a binder plate
They already make those. Cheap commercial grade ones are about $1.50 and they go up from there.
Or is this a special Fulthrotl designed version you are talking about?
480sparky
Iowegia
....Or is this a special Fulthrotl designed version you are talking about?
I think he's missing the boat. He needs to start making receps for the audiophile crowd for $400 a pop.
Karl H
San Diego,CA
Trust me dont do it! If you do comm or Industrial your guys
will strip too much wire and in a metal J-Box can be real
dangerous. I have a couple of building managers that I work
for that will not allow them just for that reason.
Fulthrotl
nope... just a spec. grade device. home desperate even sells them.
the blade contacts are a little heavier, and don't loosen up in service
over time as much. home desperate sells them for about $5.
basically hospital grade device without the certification or price.
480sparky
Iowegia
As opposed to the exposed screws?
Karl H
San Diego,CA
I knew you would say that. lol
So you guys are saying that no matter what in service
you were always alllowed to turn off and shut down an modular
furniture farm to remove a plug during business hours?
480sparky
Iowegia
"Yes, Ma'am, I realize it's an inconvenience on your part to shut the computers down, but it would really be an inconvenience for my family to have to plan my funeral. I can, if you like, re-schedule this for off-business hours at ______ rate....."
iwire
Massachusetts
What I am saying is that I do not do my work today bassed on what you want to do a year from now.
Personally given your example it sounds like a real bad idea to just go for it because you will look like an idiot if it does short and take the circuit down unexpectedly.
electricalperson
massachusetts
i use the stab in connectors in the halo cans and never had a problem. you can wire up a light so fast with those things. problems only occur when they are installed wrong. if its UL listed then its fine. i still dont backstab devices i use the screws. just the way i was taught and how i like to do it.
and i wrap tape around devices in metal boxes :smile:
480sparky
Iowegia
Yep.... a year or two from now, that tape is going to just fall off anyway and uslessly hang off the wires when you pull it out.
