360Youth
 - Newport, NC
I like to use wagos for a few things.  Mostly for splices within a panel box or connections in  strip receptacles (they take up less room than a wire twist and a nut).  Outside of the cost factor, I am not sure I am up to using them in large quantities spread out throughout a circuit.  If there is a problem I do not want to have to check every wago in every box for the one wire that slipped out.  Also, when you inevitably have to add or remove something from an outlet box they are more laborsome to do so than a good 'ole wirenut.
I really like the wagos in recessed lighting. It cuts time in half, at least, but you do have to watch them. I have more problems with the factory connection than the field. But so far they are worth what few call backs I have found.
			I have never seen a halo can with wagos that has all the wires seated properly.
