A Bosch 500 I recently put in had a cord from the factory, but there was an optional hardwire kit you could buy.I wonder whether the instructions address converting them to hard-wired as an option.
No grommets around here. The hole in the side of the base cabinet isn't sharp or jagged, so that is the 'approved means'.For those of you that see dishwashers with a flexable cord, do you install the code required grommet ? 422.16(B)(2)(5) I think.
Green tag from me.If the dishwasher doesn't come with a factory installed cord, I install a appliance cord and put it into a GFI outlet under sink base.
Is there anything saying you can't?
The hardwired option still has a cord but instead of it terminating into a 5-15 plug it has a non metallic J-box on the end of the cord.A Bosch 500 I recently put in had a cord from the factory, but there was an optional hardwire kit you could buy.
Inspectors around here dont always trust us to size the cord. They sometimes ask to see the installation instructions, as 422 .16(B)(2) says the cord you use has to be 'suitable for the purpose in the installation instructions'. Which is silly. You should just be able to size the cord based on the namplate.If the dishwasher doesn't come with a factory installed cord, I install a appliance cord and put it into a GFI outlet under sink base.
Then you haven't seen my work!I have never installed, nor even seen a cord-connected dishwasher or disposer.
More a means for the homeowner to turn the disposal on and off. Air switches are very very rare around here.Do you install a single-pole switch above the counter as a disconnecting means for the dishwasher? A homebuilder that I worked for in the 80's did that.
Curiouser and curiouser.Then you haven't seen my work!I haven't hard wired one in 30 years.
I have never seen one in the 40 plus years I've been involved in the electrical tradeAir switches are very very rare around here.
I have always had to install an appliance cord on every disposal I've installed. If I had to guess, I'd bet the majority of the disposals were already installed and I had to crawl inside the cabinet to wire the cord.I failed to mention, none of the disposals I've installed had cords either. I buy an appliance cord and put on them. Guess it depends on where the disposal is bought. All the ones "Big Blue" sells (that I've seen) don't come with cords. I have put air switches on a few.
I think the only disposal I put a cord on prior to installation, was my own. Yes, painful even for a young person.I have always had to install an appliance cord on every disposal I've installed. If I had to guess, I'd bet the majority of the disposals were already installed and I had to crawl inside the cabinet to wire the cord.
Painful!
Ron
So, on the topic of supplying a dishwasher and a garbage disposal from a single 20A 120V branch circuit:Same here I think its under 430.53 that the motor has to be 6 amps or less. 10A or less for the dishwasher per 210.whatever.
Right but not less than 6A.If the motor FLC is bigger than 6A, then the maximum size SCGF OCPD is already 20A, and likely 430.53(B) would allow the install.
6A and under is covered under 430.53(A), so may be possible on a 20A branch circuit.Right but not less than 6A.
I just looked it up and (A) seems to say just several motors. (B) includes 'other loads' aka dishwasher.6A and under is covered under 430.53(A)
Yep!I have always had to install an appliance cord on every disposal I've installed. If I had to guess, I'd bet the majority of the disposals were already installed and I had to crawl inside the cabinet to wire the cord.
Painful!
Ron
