redz2500
- Concord,ca 94520
Hello, some jurisdictions in my area are requiring us to bond the water within 5 feet of the building entrance. They are saying that this is not an option under any circumstances. The way that I interpret the code. I only have to do that if I’m wanting to use it as a grounding conductor to extend to another electrode.
For example of my exact system:
5/8 ground rod for my primary electrode.
5/8 ground rod for my secondary electrode.
Number six conductor from the main service panel to either The water heater or a hose bib on the exterior of the home.
Normally, I would just do this and appease the inspector however, this home has no attic and no crawlspace. Wrapping conduit all the way around this home would be incredibly costly. This required poonormally, I would just do this and appease the inspector however, this home has no attic and no crawlspace. Wrapping conduit all the way around this home would be incredibly costly. Do not feel that this is a requirementdo not feel that This required per the NEC or in my case the CEC (California).
