I have a client that would like a grounding bar installed in their welding bar so that they can clamp their welder ground to it. Is this a common item? I was always under the impression that while welding you ground to the equipment that you are welding. They have requested a ground bar with a grounding conductor connected to a ground rod.
Any issues/concerns with this?
