I am a retired electrician and helping my daughter build her house. The well driller would not let me ground his well casing from the service panel to his well casing about a foot above grade with a #4 bare wire.
My question is: Is the well casing required to be grounded by the NEC? The pump motor has the green ground wire and he used 12/3 UF to go back to the controller with the ground wire connected.
