I have a customer who has a 5500W portable generator that he connects to a sub-panel in his garage (suicide plug to a receptacle that crosses about 20' to the sub-panel...NOT my work! I'm talking him into redoing it). The sub-panel is interlocked with a 30A DP coming off a main panel which separates the POCO from the generator.
The trouble is that when the well is sourced from the POCO it runs fine...momentary inrush, then settles at about 7-8 amps. But, when I switch to the generator it surges to about 27amps and stays there! The breaker hasn't tripped even though it is a 20A DP, but I believe that the well pump cuts out due to thermal overload after about a minute. It is a 1/2hp at about 400'. The well guy feels that it is undersized for that depth, but we can't figure out why it draws so much on generator power. When on POCO power I get about 123V on each leg to ground/neutral (sub-panel is not bonded to neutral). When on generator power I get about 130V.
I tried hooking up my own generator (same size/capacity) and get the same results with it.
From what I can tell, the other circuits (lighting/receptacles) that are fed from the sub-panel seem to operate fine using the generators.
An ideas as to why this might be happening?
Thanks...
Thanks...
