In general, cables with PVC insulation and jacket can withstand immersion in clean water for a [FONT=Arial,Arial]short period [/FONT]of time without being damaged as long as the ends are not immersed. For example,
a building may be subject to rainfall while under construction, and water may come in contact with the outer jacket of nonmetallic-sheathed cable. This is not prohibited by the [FONT=Arial,Arial]NEC[/FONT]. The UL Standard for Safety for Nonmetallic-Sheathed Cables, ANSI/UL 719, requires Dielectric Voltage-Withstand Tests after 24-hour water immersion of cable samples (with ends in free air).
If the ends of the cable are immersed for any period of time, however, the internal paper wrapping around the bare equipment grounding conductor will absorb and transfer the water into the cable assembly. The water may then start degrading the insulation or possibly corrode the conductors.
