Carultch
- Massachusetts
So I guess ohms law is giving the resistance when the bulb is hot? That doesn't make sense to me
Ohm's law is the idealized case that resistance is independent of electrical operating conditions. It is a property of size/shape, material identity, and temperature. As long as temperature isn't significantly changed, you can expect resistance to remain unchanged.
Due to the fact that an incandescent light bulb has to heat up to 10 times the absolute temperature in order to work, resistance will indirectly depend on the voltage. But it really is depending on the temperature of the filament. Suppose you heat it up to its operating temperature with a separate source, instead of powering it with electricity. You will find its resistance is close to what you'd expect when operating at the rated voltage.
