Unlit bulb is about 20°C at room temperature.
Energised it is about 25000°C
The ohms are much different.
Ohm's law not violated.
2500°C
Apologies for the typo.
That is ok, you can just put that extra zero on my payment2500°C
That'll make it $0.000 then............That is ok, you can just put that extra zero on my payment![]()
If I remember the story correctly, the first actual product of what became Hewlett-Packard was a high stability audio oscillator that indeed used a light bulb in that or a similar circuit for amplitude stabilization.
I know. I am one of those old-timers.Larry, the model railroad power supply is using the same method as oldtimers who screw an Edison base bulb instead of a new fuse to troubleshoot short circuits.
Absolutely, same as above. Fuses or breakers.I use a headlamp and jumper clips to troubleshoot vehicle short circuits. Saves buying fuses, plus gives visual indication of when the short goes away!
We did that in elementary school science class.Or the original electric hot dog cooker, suicide cord, two nails and a light bulb in series. When the light goes out, the dog is cooked an no longer passing current.![]()
I would imagine the resistance is nonlinear based on the input current. Your meter is probably using micro/milliamp currents to take readings. That bulb is not getting hot...........
Try 2500°C instead. Very close to color temperature of bulb for incandescent.Unlit bulb is about 20°C at room temperature.
The clue is in the D of LED!one more just for kicks - 15 W LED bulb measures 197K ohms both directions.
A 6 W LED bulb measures 1.1 megohm in one direction an >10meg in the other:roll:
You could consider that a resistance bridge, like the classic Wheatstone bridge, measures resistance directly. You are adjusting a variable resistor for a null in the bridge circuit independently of the applied voltage and the resulting current.Nothing new here. I had thought the temperature coefficient for tungsten would not be constant from room temp to incandescent. Apparently it is pretty constant.
Alpha = .0044 1/C
As others have said, for a typical 100W bulb,
resistance at 20C = 12 Ohms
resistance at 2550 C = 144 Ohms
Attached is a graph of the data I found
Interesting thought:
The resistance cannot be measured directly.
Voltage can be. Current can be.
Meters measure V and I and calculate the resistance.
the worm
I refuse to accept anything less.That'll make it $0.000 then............![]()
Couldn't resist it.......I refuse to accept anything less.
I have been going nuts all day trying to figure out why the difference yet when wired in series the voltage at the bulbs calculated correctly.--bulb were hot....
Thank you both
Why would you wire lamps in series? Just an experiment?
