I think he takes the "hands on" approach. Not a bad thing. But let's listen to what he has to say.Agree - I suspect he thought a hands-on experiment would more useful to drive home the concept in this case.
You just had to throw that 43/60 in there. I was feeling good with the answers now tell me how you got 43/ 60
:thumbsup:Of course. However, these are older bulbs that have 60 watts on them. If I remember the others stated 43 watts or whatever.
That was probably not quite correct. I was just trying to say that newer bulbs may be labeled "60 watts", but they are really only 43 watts. So you may need to use 43 watts in your calculation instead of 60.
I believe newer bulbs are still labeled with 60 watts, although they only use 43 watts. Its "truth in advertising" turned on it's head - manufacturers are actually required to lie about the wattage a bulb uses. A 43 watt bulb will be labeled "60 watts".
However, you said you used an ammeter and you got the correct reading for current. That seems to confirm you do actually have older lamps (probably made before the 2010-2014 range when they first started to phase out incandescent), and that they probably do use 60 watts.
As others have mentioned, the resistance of the filament is much lower when its at room temperature. And the resistance goes up a lot when the filament starts glowing red hot. So that's why you just can't measure the resistance. However, if you use an ammeter to measure the current when the bulb is operating, you should get the expected current which is 60W / 120V = 0.5 amps.
Then if you use R=V/I, you can calculate the resistance for the "hot" filament which is 120V/0.5A = 240 ohms, as you expected from your first post.
I think most (if not all) are labeled 43 watts, in the 43/60 example, but packaging may indicate it is 60 watt equivalent/replacement in some way or another. Lamp itself hardly ever states any "equivalent" rating from what I recall seeing.That was probably not quite correct. I was just trying to say that newer bulbs may be labeled "60 watts", but they are really only 43 watts. So you may need to use 43 watts in your calculation instead of 60.
There is a classic circuit called a Wien Bridge Oscillator which uses the changing resistance of an incandescent lamp to provide for stable operation.
Oscillators depend on positive feedback through an amplifier to get oscillation. The problem is that this positive feedback quickly drives the system into saturation. You need some technique for having positive feedback until the signal amplitude gets high enough and then limiting the gain so the amplitude doesn't get too high.
In the Wien Bridge, an incandescent lamp is used as a resistor in the feedback path setting gain. As the signal amplitude increases, more current runs through the lamp, it heats up, and its resistance goes up, reducing the gain. A very clever approach to keeping the system in its linear range.
-Jon
How would a tungsten lamp not be linear as it heats up in the reference to resistance?
If you know the cold resistance, the hot resistance, wouldn't it basically be a straight line between the two?
The thermal time constant of the lamp was much longer than the period of the sine wave, so the lamp was responding to the RMS of the sine wave, not the instantaneous value.
As the RMS value of the sine wave would climb, more current would go through the lamp, and the filament would heat up, and its resistance would go up and the feedback gain would go down. The other resistors in the feedback path were selected so that at the desired output amplitude the gain would be unity.
As far as the _signal_ itself was concerned, the lamp was a nice linear resistor.
As far as the envelope of the signal RMS averaged over time, the lamp was a non-linear resistor (resistance changing with amplitude) such that you got the right amount of feedback at the right signal amplitude.
Note that the temperature coefficient of resistance does change with temperature, but that is secondary to the point above.
-Jon
-Jon
If I remember the story correctly, the first actual product of what became Hewlett-Packard was a high stability audio oscillator that indeed used a light bulb in that or a similar circuit for amplitude stabilization.
Jon, you are way past my pay grade... I see a bulb turning on, and it goes from cold to hot.
We use the 60 watts as a fixed known. Then, this happens!
Based on the new information, 43/60. I would energize this light. Let it get to operating temperature, then put an amp probe on it.
Now you can determine what the true resistance is at operating. And, what the wattage is.
Also, you can now measure the resistance cold and see the difference between room temp and operating resistance for clarity.
This is what we did. We were able to measure the amps and we got the resistance which matched pretty closely to what ohms law was saying. The problem was that I was expecting an unlit bulb to measure around the same as ohms law would yield. The ohms law calculated came very close to the actual ohms when the circuit was energize fully.
