K8MHZ
 - Electrician
Old Man, I am with you and probably older.
I contend that by stating RMS values, a constant load resistance is implied, and it is incorrect to apply RMS values in a non-linear problem.
Also, the way the question is stated, 200V appears across the filament which rules out any series components.
Now, it is conceivable that the frequency is high enough that the stray inducance of the filament and its connecting wires reduce the applied voltage, although that would be a special case.
In other words, it is a trick question, and the OP can come up with any scenario he wishes to make "1kw" wrong.
RMS can mean different things. In electricity it can mean the DC heating equivalent of an AC source. Mathematically it means root-mean-square and depending on the wave form it may or may not be equivalent to the DC heating value as we assume a balanced unvarying wave form and the value sparkys use is a measured value with calculations to support the measurement. Cart before horse, but it works for 99.99 percent of what we do.
So, the info has been omitted is what RMS means. Does it represent a heating equivalent or a mathematical value? If they were invariably one and the same, this thread would not exist.
As far as a trick question, perhaps. It is one that can provide some enlightenment, if you pardon the pun. It sheds some light (sorry, couldn't resist) on how our trade standards may have some exceptions, exceptions that since are very rare, may not be realized by the average sparky. But at some point we may encounter a situation like Gar has described where PAVE does not equal VRMS times IRMS and a little voice should tell us to look for non standard or imbalanced wave forms and unstable loads.
This should also teach us that an incandescent bulb is not stable and it's stability decreases as frequency decreases. Connect a watt hour meter to a bulb along with a volt meter and an ammeter. Turn the switch on and off for a half second with a 50 percent duty cycle (1HZ superimposed with 60 for half a duty cycle) and see if Pav x T = Irms x Vrms x T. Any REMF coming from the rise and collapse of the magnetic field in the coil of the bulb surely would affect the readings at 1Hz making what was once a nearly pure resistive load into an inductive and resistive load.
